Discuss Design Current in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
hossamozi
hi all
I want to ask you How can I calculate the design current of the motors such as Air conditioning ,
washing machine ,dishwasher? and what the rating of Each?
hi all
hi there
with air conditioning you have to be carefull as the heat pump side tends to be more than the cooling on some types of condensing units.
but these days design of AC units has come along way most run ona 13 amp supply but for bigger units check with the manufacturer
rest as name plate allow for a higher start up current c type mcbs
cheers
hi there
cheers
can you give me formule to apply it to calculate the design current of it for example if we have 1.5 hp AC how can i calculate the design current?
please give me an example
1HP = 750W (or thereabouts)
On single phase it's easy peasy lemon squeezy to calculate current drawn ( I = P/V)
Three phase is a bit trickier, try this The 3 Phase Power Resource Site - Three Phase Power Solutions
Proper motors generally have the FLMC (Full Load Motor Current) on the Rating Plate. This is the current drawn at full power (not start-up!)
Size yr CB for FLMC (Type C or D are common options to handle Inrush or Startup Currents).
Size Overload Relays (if fitted) as per manufacturers charts (each manufacturer should publish Heater Characteristics to enable proper choice)
Reply to Design Current in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Im currently in my apprenticeship and completing an assignment that involves cable calculations. Im currently stuck on how to find the design...
So I’m doing my level 3 design project at the moment, and I’m on the question where you do all the calculations on each circuit, I’ve taken the...
I'm working on a robotics project and currently we are designing a battery. This battery is dedicated to the motor driver and two BLDC motors. I...
Sorry if this has already been posted before, but it's not something I can find a definite answer to. Does anyone know if passing the 2396 Design...
