Discuss Design of Small installation in the UK Electrical Forum area at ElectriciansForums.net
C
cuzzy1973
Hi
Any Domestic Installers ,any help would be welcome
Im would like to put in a ringmain,a lighting circuit,and a hob and oven
This is into my new extension.i intend to run an swa cable from exsisting
supply 7metre run,fit new board in extension and run circuits from this.
what size swa cable is correct to use.
How long is a bit of string?
No one will be able to give an accurate answer without a lot more detail. This work is notifiable so unless you are able to test, certify and notify you'll be breaking the law.
Get an electrician in to undertake a proper assessment of your needs and advise you accordingly.
Cuzzy ... you may be amused or peed off with all the indirect answers this is because you haven't supplied anything like the info required ... your having 2 heavy loads fitted too yet no ratings given and we don't know the existing loading on your supply ... really need to get someone in or supply us with all required info.
Sound like someone has spent a little too much on the extension and trying to save a bit of cash, besides its only a few wires how hard can it be?. Please don't injure yourself and get an electrician in.
Reply to Design of Small installation in the UK Electrical Forum area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
