Hi Guys,
I am an electrician, profiles says DIY
Seeking advice from those that install LED lighting. Kitchen is 3.7m x 3.4m. Basically 2 x worktop areas either side of the kitchen (3.4m walls). I've read here that most recommend Led lights sited 1m from walls. With my limited knowledge, I'm thinking 3 rows of 3. Is this overkill? Would 3 watt LEDs be sufficient or possibly 7 watt?
At the moment 1 x 4ft fluorescent in use, which appears to be adequate.
