Hi there. Quick one for you hopefully. Used an mk grid switch dimmer to switch GU10 led lamps. Load is well within the rating but soon as dimmer is on there's a hum. From both the dimmer and other two way switch and also the mcb. Take it out it all stops. The mk instructions do state to not use a different load that mentioned and LED weren't. So my mistake.
Has anyone come across this and found any decent grid switch dimmers?
Grid switch as its a two gang with a two way and a one way switch together. One dimmer one normal.
Personally, I use the vPro from Varilight. They do adapter sets for use with other grid systems.
I've had one bad dimmer module that required replacement (firmware crashed or something under certain switching conditions). Had no problems with compatibility.
Great thanks for the info. I'll have a look into them.
[automerge]1597784124[/automerge]
Northumberland
United Kingdom
If other, please explain
I am a practicing Electrician with a 1st class Bachelors of Engineering in Electronic Design with honours
Dimmer switch for LED GU10s
Lighting Forum
2piesFC,
MJPD29,
