Discuss Dimmer Switch ? in the Industrial Electrician Talk area at ElectriciansForums.net
Hi all, im a bit embaressed to ask this one, as im City and Guilds qualified ! :-
Is it ok to fit a dimmer switch to control a ceiling light that has a transformer fitted in it ??
The light in question has 4 x halogen capsule bulbs in it, that are low voltage.
Thanks in advance for your help.
Yes, but make sure you get a dimmer that will dim transformers, and make sure said transformer is dimable type. Usually says on tranny.
Reply to Dimmer Switch ? in the Industrial Electrician Talk area at ElectriciansForums.net
