Discuss Diode used with Relay in the Electrical Forum Canada area at ElectriciansForums.net
W
whazza22
Can anyone tell me what the result would be if a diode was put in the opposite way round in a bed light relay? (e.g. a bed head light for a hospital bed)
In the correct terminals but the black stripe on the diode in the wrong way. And its in the extra low voltage side.
Probably a short circuit. The diode on the relay is to short out the negative voltage spike generated
by the de-energizing relay coil (the moment when the supply to the coil is off). If + is connected to the anode
then the diode is conductive.:)
Virtually a dead short would be created, a fuse would hopefully of failed before any control circuit switch welded closed.
Even oof its extra low voltage and functioning correctly?
Hi,
If the diode is connected across the coil terminals with incorrect polarity, the relay would not energise as the diode would be the path of least resistance, (google blocking diode or flywheel diode).
It might well be a zener diode Zener diode - Wikipedia, the free encyclopedia as nothing else would be in circuit and still work, not seen one used in this way though.
Reply to Diode used with Relay in the Electrical Forum Canada area at ElectriciansForums.net
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
