Distribution Board Height in a Small Cottage - Full Rewire | on ElectriciansForums
Discuss Distribution Board Height in a Small Cottage - Full Rewire in the UK Electrical Forum area at ElectriciansForums.net
cornwall
Right doing a job for my registration assessment so got to get it spot on. Job is an old cottage but been stripped right out and complete rewire. Am I correct in saying the dB hight has to be at the same hight as light switch? Seems far to low if u ask me.
recommended height for a DB is between 1400 and 1500 mm above floor level. that's in the building regs, not BS7671. however, this applies to new builds, same as the 450mm -1200mm for sockets and switches. on a rewire, it's down to you and the client to decide where and how high things are fitted.
So it could stay at the original hight just need to replace old 16mm tails and earth.
as long as it's accessible and not in a stupid location, then it can stay. don't forget the cable entries into metal CU should be secure and the IP rating compliant. i.e. IP4X top. IP2X elsewhere. what's the earthing system?
My CU is about 2m off the floor on the wall in a kitchen cupboard which you realistically can just about reach if you are over 6ft. A mate of mine has his under the stairs in a tiny cupboard about 400mm from the floor.
I'm glad u said that I just put my second fix list in and forgot the gland for the tails!! It's tncs earthing.
I did a CU change a few years ago, then the kitchen was refurbished. I had to move the CU again. As space was limited, I suggested housing the CU in one of the wall units, with suitable access. I obviously hadn't explained things properly, as when I went back to 2nd fix, the CU was in a cupboard right above the double oven :mad:
If your assessor is doing his job properly then he won't take 'it's what the guys on the forum told me' as a suitable answer if he asks why you decided to locate the CU in a certain place!
And I very much doubt that would be the answer the op would give his assessor.......There is no harm in seeking advice from other electricians, after all this is what this forum is here for so electricians can discuss things!
Reply to Distribution Board Height in a Small Cottage - Full Rewire in the UK Electrical Forum area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
Just a small correction..
    • Informative
    • Agree
No, which is silly, I guess they expect you to use the double pole isolator at the start of the circuit to isolate the fan?
2 3
10K
