CDB
Morning all,
Thumbing through the OSG guide today and I have a couple of questions regarding the above table.
Firstly, just a idiot check but electric showers would fall into no.5 water heaters of the instantaneous type. I know this but so often doubt myself.
Secondly, No. 9. Am I right that this would be applied across all circuits to see if the main switch and supply are big enough. Its thrown me because if that's correct I would expect it to be last in the table.
Thirdly, No 10. Good old socket outlets. When would this apply if we typically using the standard 'socket outlet' circuits. Could I apply this in a workshop where I have a welder that takes a 16A C-Form connection on a radial with other outlets e.g to a fan? If someone could provide an example that would be great.
Chris
Chris
