Hi,
I'd like to make a new ceiling lamp for my bedroom using LED chips. For the White LEDs no problem but for the RGB ones i have the following Issue:
I'll probably use LED COB chips RGB 36 Volts, with a current regulator.
To easily change color I want to use an RGB wifi controller but online i found only 12/24 volts ones (they are specific for LED strips).
How can I solve this problem?
The LED Specs are: 30-36 volt, 600 mA
I hope you can give me an advice.
