Discuss DIY pool pump installation (amps question) in the UK Electrical Forum area at ElectriciansForums.net
Keith_C
Good morning all!
I think I have the right amps for a new inground pool pump but I need to ask a pro. I don't want to burn my house down ?
The old hardwired pump I'm removing has worked great for years. Its amps are stated like this, "7.8 - 7.4/14.8." The new pump I want to replace it with has this "11.5/5.7 amps." Do the lower amps on the new pump present a problem? I don't think so, but I need to ask.
Thank you!
Keith
should be fine.i assume that the stated amps are at each voltage, 110V or 220V.
The new pump has higher amps.
I thought that because the higher amp number for each pump was on different sides of the slash mark, that was just a different way of indicating the range of amps, not an actual numerator/denominator. So am I wrong? The new pump has more amps? Not a problem I'm told.
surely old pump is higher amps as in 14.0 as opposed to 11.5 for the new pump??? it's still 14A at 115V (old) against 11.5A at 115V (new).
Reply to DIY pool pump installation (amps question) in the UK Electrical Forum area at ElectriciansForums.net
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
I need advice regarding an electronic problem on my Hayward Power-flo Matrix pool pump. I notice that : 1. Neutral wire from source has become...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
