Discuss DIY replacing main service panel in the DIY Electrical Advice area at ElectriciansForums.net
DIY If I replace my main service panel, is it required that I replace all the wiring in my house , Ohio small 750sq foot home
Reply to DIY replacing main service panel in the DIY Electrical Advice area at ElectriciansForums.net
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I have an interesting scenario that could use some feedback. I have 200A service in my home with a sub panel running to a detached garage...
I live in las vegas nevada. I'm installing a sub panel outside that will be a 125 amps.I want to run the right wire from my sub panel to my main...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
