- Jun 1, 2025
- 3
- 0
- 1
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Had new EV charger fitted 7kw, on a 40A rcbo fed with 6mm twin & earth.
In use the DNO's service cable, two core lead sheathed gets hot to the touch. Like I'd estimate 70 degrees plus.
Their cable seems undersized - it's smaller than the 6mm T&E!
Please see pictures. Is this anything to worry about / contact DNO about?
