N
Nicebloke
Just had a call to give someone a quote for dry underfloor heating which I declined as I haven't done it before and I'm sure it's within my capability to do it but I wouldn't quote for something I have no experience of.
Just curious if other electricians do dry underfloor heating?
I do the electrics but get the tiler to lay the mat!
Chicken!!
I hate the mats. I much rather do the separate wire type.
But as above, its just a matter of good planning. If I can i install two probes (one as a spare) or make very sure the probe conduit works properly.
Its a pain if the probe fails and its all tiled in......
Did some DIY, ten years ago and it's still working. My spark even tidied up the wiring by putting in FCU eight years ago. :oops: I don't mind tiling either so long as the surface is level :D
Yep, it's no problem. As has been said, assess output required, allow for under mat/wire insulation if going onto a solid floor etc. I always measure the insulation resistance of the mat prior to the tiles being laid and after - that way there is no argument if the tiler damages the cables:)
That's generally in the manufacturers instructions as well as measuring the resistance of the sensing probe wires. :)
It's pretty easy. Have an under Matt, prime it with some pva type stuff and lay the elements which is on a sticky grid. Can get a bit tricky at the end if you have some spare, gotta detach it and snake it about. There's a thermo sensor at the beginning that gets cut into the matt.
a switched connection unit on the other side of the wall with the controller at switch height.
We've only done a couple however the hardest part was probably finding the feed for the SCU lol
Do any sparks do underfloor heating?
Nicebloke,
D00DY_T00DY,
