N
Nicebloke
Just had a call to give someone a quote for dry underfloor heating which I declined as I haven't done it before and I'm sure it's within my capability to do it but I wouldn't quote for something I have no experience of.
Just curious if other electricians do dry underfloor heating?
I do the electrics but get the tiler to lay the mat!
Chicken!!
I hate the mats. I much rather do the separate wire type.
But as above, its just a matter of good planning. If I can i install two probes (one as a spare) or make very sure the probe conduit works properly.
Its a pain if the probe fails and its all tiled in......
Reactions: DPG
Did some DIY, ten years ago and it's still working. My spark even tidied up the wiring by putting in FCU eight years ago. :oops: I don't mind tiling either so long as the surface is level :D
Yep, it's no problem. As has been said, assess output required, allow for under mat/wire insulation if going onto a solid floor etc. I always measure the insulation resistance of the mat prior to the tiles being laid and after - that way there is no argument if the tiler damages the cables:)
That's generally in the manufacturers instructions as well as measuring the resistance of the sensing probe wires. :)
I will when uncertain about something, best to cover your #### . :D
Reactions: Hellmooth
It's pretty easy. Have an under Matt, prime it with some pva type stuff and lay the elements which is on a sticky grid. Can get a bit tricky at the end if you have some spare, gotta detach it and snake it about. There's a thermo sensor at the beginning that gets cut into the matt.
a switched connection unit on the other side of the wall with the controller at switch height.
We've only done a couple however the hardest part was probably finding the feed for the SCU lol
Reactions: FatAlan
Do any sparks do underfloor heating?
Nicebloke,
D00DY_T00DY,
