We have a mini split AC Inverter. We need electrical wire for the second mini split AC inverter.
Can we get a wire branch from the first AC terminal?
Do the voltage drop/sag and fluctuation occur?
Thanks, If the cable is thick enough and the fuse capacity is sufficient, is there any other problem?
When the second AC is turned on, does the voltage sag and fluctuation occur in the first AC? Can it be harmful to the electrical board and compressor?
When the second AC is turned off, does the voltage spike and fluctuation occur in the first AC? Can it be harmful to the electrical board and compressor? (and vice versa)
