Apr 15, 2024
18
Middle East
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Hello,
We have a mini split AC Inverter. We need electrical wire for the second mini split AC inverter.
Can we get a wire branch from the first AC terminal?
Do the voltage drop/sag and fluctuation occur?
You should install an extra wire to the distribution panel.
Reactions: Shervan360
Thank you, Could you please tell me the problem with the above solution?
Do the voltage drop and fluctuation occur or other problems?
You will not be able to turn them off independently to work on them.
You may be overloading the existing cable when you add the extra load.
Thanks, If the cable is thick enough and the fuse capacity is sufficient, is there any other problem?
When the second AC is turned on, does the voltage sag and fluctuation occur in the first AC? Can it be harmful to the electrical board and compressor?
When the second AC is turned off, does the voltage spike and fluctuation occur in the first AC? Can it be harmful to the electrical board and compressor? (and vice versa)
These are questions to complicated for a simple answer
It depends on many things
Cable size
Cable length
Load type and current
Filtering and harmonic distortion
Power factor
For this reason it is normally best to follow manufacturers instructions and give each their own supply cable.
Middle East
Do the voltage drop and fluctuation occur?
Shervan360,
James,
