Dodgy electrician consumer unit change | on ElectriciansForums
Discuss Dodgy electrician consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Nottingham
Hi guys
Being to a job today where a customer wanted a quote for doing the bonding to water and gas. She had told me that an electrician had fitted a new board with no main earth present and had told her that it would cost an additional 300 pound to get the bonding done when the main earth has being installed. The electrician has even issued her a completion certificate noting this defects with no apparent test readings at all. What i want to know is do she have a case against him for installing a new consumer unit with obvious risks present and holding her to ransom by saying she has to pay more money to get the bonding done.
MAIN PROTECTIVE BONDS please use the correct terminology, nearly as lazy as the so called electrician who changed the board and couldn't be bothered with MAIN PROTECTIVE BONDS.
I hope Westy, that the OP feels completely chastised, well said.
[ElectriciansForums.net] Dodgy electrician consumer unit change
yeah why is that?
ISCO was a product of WT Henley, I think it stands for Ironclad Service CutOut
Reply to Dodgy electrician consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
What is the distance from the point outside the house to the shed?
Our house in a row was built in 1971 and we have metric cables with cpcs for the lighting, top of the row imperial and no cpcs.
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
Unfortunately they will not respond in writing, this came about because I threatened to complain to the NICEIC
