Currently reading:
Darkwood
Staff member
Mod
Supporter
This is part of an article in the PE mag. It has been printed in more than one. I don't know why you would do that. Perhaps the lights were fed from a centre tapped supply...
It doesn’t make a lot of sense that, you’d have thought that some editor worth their salt would have picked up on it. If the downlight can’t work then . . . . ?
We fitted 9 of that range of downlights recently,2 were dead out the box, not even a brief flash or pop at first switch on. One of the 2 replacements was dead too. 2 had faulty LEDs the other had faulty electronics.
A couple of lads I know have been left to sort this lot out, they've only got a six hour window and it all has to be done with no service outage. Started off as a quick DC PDU swap and sort of got a little bit bigger...
That's roughly 500 fibre optic cables badly installed...
Under the floor:
Top of rack:
Bottom of rack:
These pointless labels are still being fitted to samsung stuff, found during appliance testing, the first on an IEC lead, the second on a VGA cable. I first started seeing these over 6 years ago. I would have thought someone at samsung would have stopped them by now.
Whilst doing my day job (painting) the light in my customers house started to flicker. So I removed the cover to find this monstrosity,
It's a council house so he's getting them to fix it,
Every screw was lose (terminals and fixings) I tightened all the terminals and removed the fixings. This way it can be fitted ontop of the ceiling instead of into the ceiling
IMG_20180305_110442.jpg IMG_20180305_110150.jpg IMG_20180305_110453.jpg IMG_20180305_145422.jpg
I was recommended to a chap who's doing up his bungalow, when removing the old kitchen base units he came across this little gem....
After nearly 11 hours of hard graft it's all resited into a cupboard,new CU [The much maligned BG which I've never had a problem with],tested and certified. :) The 'after' picture was before it was quite finished and I'd just connected the tails in quickly to do the live tests, they were subsequently redone tidier. :)
I particularly like the graffitti...I mean, who doesn't scribble their wiring ideas on the wall?
Redecorating recently, I stripped off some wallpaper near the thermostat in the hall, and there, preserved for all time, was the "working drawing" from years ago...and yes, it corresponded exactly to the wiring in the (now defunct) stat itself...except it wasn't quite defunct...it was unused and surplus to requirements, but still packed a punch when I fiddled with it...shoulda used my voltpen, dammit!
After nearly 11 hours of hard graft it's all resited into a cupboard,new CU [The much maligned BG which I've never had a problem with],tested and certified. :) The 'after' picture was before it was quite finished and I'd just connected the tails in quickly to do the live tests, they were subsequently redone tidier. :)View attachment 41245 View attachment 41246 View attachment 41245 View attachment 41247 View attachment 41245
And that’s why they call you @Dave OCD, by the way was the spirit level for us to see? Just asking! Nice job.
1960s install - wiring diagram of installation folded and placed next to Wylex 3036 - how great is that. Respect to the ‘real’ sparks - that would take me 2 days just to draw that diagram. We’ve got it easy! (Don’t tell @Pete999 that I said that)
Too late!!!
Too late!!!
Too late!!!
