Search for tools and product advice,
Discuss does the hieght requirments for sockets apply to extensions ? in the Australia area at ElectriciansForums.net
J
Jak1708
alright all
i have 1st fixed an extension for a builder but hes moaning that this electricians normally put all the heights for the sockets and switches at the height required for disability that it says in the building regs but i thought that only applied for complete NEW buildings not a new extension to an existing houses
any help on this would be great ?
thanks
jack
New build as far as i'm aware.Last extension i did,all sockets and swiches tallied up with the original building.
New sockets and switches should according to BS 7671and part M of the building regulations be fixed at a height that will assist people whose reach is limited.
This only applies to new builds and does not apply if you are adding to existing wiring in your own home or an extension.​
Reply to does the hieght requirments for sockets apply to extensions ? in the Australia area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
