Discuss Does workshop equipment such as lathes require RCD protection. in the UK Electrical Forum area at ElectriciansForums.net
Not the machine specifically but if they're are plugged in then it may be a requirement under 411.3.3 for the socket-outlet to have additional protection.
But I would check with the machines manufacturers as they may require it.
Reply to Does workshop equipment such as lathes require RCD protection. in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone… I’ve attached pictures for your leisure.. so basically the customer does not have any RCD protection.. 3036 fuseboard is in...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
