Discuss dol starter needed for converted 1 phase bradbury car ramp? in the UK Electrical Forum area at ElectriciansForums.net
M
madder
Hi everyone. Our ancient Bradbury car ramp died a few weeks ago. Eventually after replacing the 3 phase IMO contacter and thermal my sparky concluded the motor was fried. Faced with the expense of changing the motor I decided to go down the 1 phase 2pole cap start cap run solution supplied through mm engineering. I've aligned and bolted the new motor in and now have to wait for my sparky. However my question is with the 3phase contactor it stored a charge to start the motor would a 230 dol starter actually do anything other than power on/power off. As the caps are now on the motor. I'm hydraulic up gravity release down so only need single direction. The motor set me back £236 shipped.
Are you sure the 3 phase starter wasn't just a DOL? I don't think there are any starters out there which store charge to start motors!
The DOL motor starter as you say provides switching but also provides motor overload protection.
I'm not entirely sure what your question is though?
Why didn't you just have the motor rewound .. I'd expect it to be cheaper than you above option!...
Did your Electrician come across as been competent and professional or was he 'I think' - 'I might be' kind of talk seen when your basic Electrician delves into things out of his comfort zone?
Why haven't you ask this to your Electrician before posting on here... surely he's had first hand on sight involvement with this and far better position to advise.
"stored a charge to start the motor" the capacitors on the single phase motor are for start and run reasons
...If you have modified the power-pack (hydraulic pump) to operate using a single phase motor,then you will need new control gear,isolators etc,which in turn will require test and inspect re;LOLER,PUWER. If you know these do not apply to the situation it is used in,then quite a lot is possible,i have even rigged one that operated via a 12 volt tipper unit,powered by the vehicle itself,for use in a remote agricultural location. As said,your electrician needs to be questioned,employed or dismissed before probing others...Aliens did this to me...i still have dreams...
Think we lost this thread ... no reply from OP and not sure his Electrical knowledge is very good and have an idea he's trying this on his own, if he was using an Electrician as suggested why is he on here unless his Electrician was lacking in advice due to lack of competence.
Reply to dol starter needed for converted 1 phase bradbury car ramp? in the UK Electrical Forum area at ElectriciansForums.net
Hi all From the outset I'm not in an electrician. I am posting here because I'm thinking the subject matter is quite specific and will prob...
6K
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
Hi All I am new on here and looking for some advice on converting a car ramp to single phase. This particular ramp is sold in 2 versions single or...
Hi all I would like a bit of advice to do with a DOL starter ill be fitting. Basically I'm replacing an old water damaged crabtree DOL starter...
Hi there, I got a call to a job, table saw (wood) tripping C/B straight away. 4kW motor on Star Delta Starter. So I get to the job, after some...
