Discuss Domestic cooker in the UK Electrical Forum area at ElectriciansForums.net
keniff
About to use one of those double outlets for oven and hob igniter just wondering what everyone's views are on connecting hob igniter straight in on the outlet plate as there is no way of over loading the hob cable. I normally fuse down with spur but this outlet plate looks handy and can both be isolated on the cooker switch!
I;m guessing that you ar erefering to the clic one.
If the hob just needs an ignition I prefer to put it on a 13A socket.
if you use a dual outlet connection box, you can fit a CCU one side and a 1363 socket to the other. then fuse plug top down to 3A or 5A. ssimplesss.
Reply to Domestic cooker in the UK Electrical Forum area at ElectriciansForums.net
Just wondering what everyone’s view on this is, if you’re mourning cooker or hob switch in cupboard close by. Would you still terminate into an...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
