R
ReeceRyley.elec
hello, i am qualified however never had to fill out the completed 3 page forms! i can test and have my fundemental testing qual.
i have been asked too. i have looked through blank niceic approved contractor cert (domestic electrical installation certificate) here are my questions
what do i put in details of the installation in exact words, if fuseboard has been changed and kitchen circuits have been rewired only. cooker and kitchen ring?
in extent of works carried out you put in what you have done. as you've replaced the CU, then your sotr should have the readings for all circuits, existing as well as the new ones.
Who did the work?
i have been asked too. i have looked through blank niceic approved contractor cert (domestic electrical installation certificate)....
Welcome to the forums. Are you an NICEIC Approved Contractor?
If you change a ccu you are now responsible for all circuits fed from it this is why everyone pre tests the circuits before carrying work out as customer might refuse the additional costs to bring it up to current regs
For example at the minimum bonding and tails need to meet the minimum required
Doing an eicr is the easiest way (pir in old term)
You put what you have done on the one cert. So consumer unit installed, kitchen circuits rewired.
As its a cu change you need to test every circuit and record the results.
looking at post #6, i'm going to ignore the OP in future.
think OP has gone off in a sulk. perhaps see him again for 2 posts next year.
Domestic Electrician Forum
ReeceRyley.elec,
Marvo,
