L
LED Lighting
I have been asked to wire up 50 door switches (similar to Door Switch Surface - Push to Break - 2 Amp - White)
The problem is as these are to be mounted just under the top of the door (to operate) the terminals will be within reach and wont meet IPX4 requirements - any ideas?
I can seem to find any enclosures to cover the terminals.
use a different door switch. there are some on the market which have enclosed terminals
I have just googled said switch and agree with post 2. the terminals are enclosed. the four holes you're looking at are fixing holes
Use ring crimps with a bit of the insulation cut off. They're a bit fiddly and the crimps might need some manipulation to get them in, but the terminals will be appropriately covered.
How do you mean? There's a clamp at the back to go on the sheath so there is no insulation showing. These switches are designed to be used on their own without any modification.
