Discuss Door Switch in the UK Electrical Forum area at ElectriciansForums.net
Use ring crimps with a bit of the insulation cut off. They're a bit fiddly and the crimps might need some manipulation to get them in, but the terminals will be appropriately covered.
How do you mean? There's a clamp at the back to go on the sheath so there is no insulation showing. These switches are designed to be used on their own without any modification.
Reply to Door Switch in the UK Electrical Forum area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi All, I am rewiring my basement, which includes the stairwell that leads from the main floor kitchen down to the basement. Here is an idea of...
