Hi all,
I woke up this morning to find a double plug socket in the kitchen is not working at all however every other plug in the house is fine, and nothing has tripped etc...
I have turned of the mains to the whole house and check behind the plug for anything obvious and all seems fine, no lose wires etc.....
I was thinking to replace the face of the socket next? I assume this is fine to do (like for like)
Hi all,
You're going to need to call out an electrician.
I presume you don't own any test gear?
It may be the face plate, but unlikely. Could just be a waste of money swapping it.
There maybe a member on here close by.
Could be a joint loose somewhere, a fuse in a spur failed etc..
Hi all,
Have you got a socket adapter you can pop in it? It may give you a little more info as to whats wrong (ie could be a missing neutral so the socket is still live but not working). If you're not a sparks approach with caution as you don't know why its gone off yet
I assume you're telling me to search for it? I did try looking but I havent found a direct answer....
here is a direct answer, hire a competent Electrician to test and repair the fault. Think that was mentioned in the original thread as well.
Hi all,
The fact you even asked this question has set off the alarm bells, gasp and double gasp
UK
Double plug socket not working...
atpm,
Lister1987,
