Discuss Double plug socket not working... in the UK Electrical Forum area at ElectriciansForums.net
atpm
Hi all,
I woke up this morning to find a double plug socket in the kitchen is not working at all however every other plug in the house is fine, and nothing has tripped etc...
I have turned of the mains to the whole house and check behind the plug for anything obvious and all seems fine, no lose wires etc.....
I was thinking to replace the face of the socket next? I assume this is fine to do (like for like)
Hi all,
You're going to need to call out an electrician.
I presume you don't own any test gear?
It may be the face plate, but unlikely. Could just be a waste of money swapping it.
There maybe a member on here close by.
Could be a joint loose somewhere, a fuse in a spur failed etc..
Hi all,
Have you got a socket adapter you can pop in it? It may give you a little more info as to whats wrong (ie could be a missing neutral so the socket is still live but not working). If you're not a sparks approach with caution as you don't know why its gone off yet
I assume you're telling me to search for it? I did try looking but I havent found a direct answer....
here is a direct answer, hire a competent Electrician to test and repair the fault. Think that was mentioned in the original thread as well.
Apologies OP, it seems I have mixed your thread with a similar one, my mistake.
as long as you didn't replace fuse with a nail, should be OK.:dizzy::dizzy::dizzy::dizzy:
Reply to Double plug socket not working... in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
