Discuss Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
What on earth is going on here then?!?!?
"Is it ok to prune my tails guvnor?? I need to stab em both into one hole. Oh, and I'll be mucking about with the meter an all"
And people sit there and try to defend the Electrical Trainee?!?!?
What planet are these muppets living on?!?!?
Cut seals? god no :coolgleamA: . I'm probably going to instal henley blocks to be honest. The existing house already has an electric shower and cooker. And this new flat is also going to have an electric shower. Oh and there's going to be a hot tub installed in the garden. I know, tell me about it. So this is why Im running a new supply in.
No, in your original post you said:
"I plan on doubling up the connections in the meter"
Just wondering what the regulations are on doubling up meter tails?
My girlfriends dad wants to convert the garage into a 'granny flat', and I plan on doubling up the connections in the meter to take a new 16mm supply to the garage. Opinions?
I think this falls under regulation 134.1.1 amongst others.
Might I suggest your girlfriends dad starts by seeking planning advice and permission from the local authority's planning department, and also that he hires an experienced electrician to carry out the electrical work.
Your new supply should be described in terms of its OCPD rating rather than cable size as the cable size is calculated after this rating has been selected and is not necessarily indicative of the power available from that supply. Consider that your 16mm cable may only be capable of safely supplying 10A under the wrong conditions!
Reply to Doubling up meter tails in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
