Discuss Dramatic increase in electricity bill since meter replacement..... in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
My parents have recently had a meter replacement and since then the electricity bill has increased dramatically. The installers claim the old meter must of been wrong. They will charge if the come out and nothing is wrong.
They have solar panels on the roof but this was already installed and was no problems beforehand.
Is this a common issue?
Is there anything I can do to prove it's a faulty meter or if it's actually OK?
could be that the meter is not recording the solar input or even adding it to the grid supplied elec instead of subtracting. (not very well put, but i'm not well up on the solar thing).
I have only had a quick look at the meter and cannot turn off supply until weekend due to my father's office. Also those damn seals need cutting ;)
However, at a quick glance this doesn't look right to me but may be my lack of experience.
[URL=http://s1244.p.com/user/craig_saunders2/media/20161116_132743_zpsvwgyunce.jpg.html][/URL]
pic not very clear. what is the white led on the meter?
Back to you original question OP. I did some work for a customer. He was informed by his supplier, that his old meter had been recording incorrectly, and he was in debit to his supplier to several hundreds of pounds. Don't know how they worked that out, perhaps on an average compared to others (he has storage heaters). They agreed on a sum he would pay back. Apparently he wasn't alone.
Prehaps the old meter was analoge and the type that turned backwards when you generated electricidy with the solar. Hence you got the feed in tarrif and a reduced bill becaust the meter turned backwards. (cake and eat it)
Why was the meter changed ? I believe solar installers have to inform the DNO if the meter can run backwards.
Yeah perhaps that is the case.
Is there a way I can find out myself if the meter is exporting the generated electricity from the solar panels back to the grid?
The amount of electricidy you export into the grid is estimated usually 50% (amount could be wrong as solar is not my field)
So its not measured by the meter the red led (depending on your meter type) indicates power used or exported by flashing. (google your meter type for more details)
Cheers Myke
This will be it for sure. During the summer days my meter was spinning backwards from around lunchtime. Basically when the hot water tank was up to temp. So it would unwind at a rate of just under 4kW so pretty quick. It's like having your oven and kettle going in reverse.
I'll be resisting as art meter until the solicitors letter comes through third mail or they cut me off.
I'll retype that...
I'll be resisting a smart meter until a solicitors letter comes through the mail or they cut me off.
It would be helpful if you can indicate by how much the bill has increased. Also what price is their unit/KWH from this you can work out how many Kw are used. You need to compare this with previous bills and cost and Kwh used. You then need to see what equipment is in their house and the amount of power they draw. Compare this with stated Kwh hours. You will then have a basis for evaluating whether the bill is fair and true.
Get another meter even if it is just a clamp on one and measure what each meter says and see if they are in agreement, if this is done at night then the solar will not be an issue
Few things, that is a security block, L N is incorporated in it, I have noticed that the red LED is in solid state which means you are generating.As for the running of the meter if you think it is running too fast, have the supplier run a load test, that is your right.
This is true.
Reply to Dramatic increase in electricity bill since meter replacement..... in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
HI folks,, Im registered as a DIY guy..I dont do much electrical around my building except the occasional replacement of receptacles, switches...
