Search the forum,
Discuss Drilled through wire sheath, advice to make safe until after Xmas in the The Welcome Forum area at ElectriciansForums.net
Hello,
I drilled a hole late last night after a long day and stupidly didn't check the wall directly under the plug socket (I know).
The RCD tripped and it appears to have just exposed the copper wires, just the sheath is damaged (pics attached).
From a bit of googling it seems there is no fix for this, just replacing the entire wire?? That seems pretty drastic.
Can anyone advise if there is a fix and also how to make it safe to have the sockets on until after Xmas. It's in our kitchen so need the power for fridge, oven etc.
Many thanks!
Hello,
Many thanks!
Where does that cable go to that is not going into the metal box?
Look at the pic closer mate. It looks like you have damaged the copper wire as well.
You will need an electrician to replace or repair that cable. Expect you might struggle with that before Xmas. It's a bit dangerous to be exposed as it is.
What are your electrical skills mate?
The entire cable does not need to be replaced. There are other options but replacing it is the best option.
Assuming that is a ring final you could for now knock another back box in, replace the damaged section and fit a socket to it.
Yeah, have turned it back on and everything works fine still
It will still work fine from the point of view of the appliances plugged in to the circuit. However it is very dangerous from the point of view of and person near it, there are exposed live conductors which presents an electric shock hazard. Plus if something was to accidentally make contact it could spark and start a fire.
Will probably trip the RCD again when he's cooking the mashed potatoes for the xmas meal as well....
Reply to Drilled through wire sheath, advice to make safe until after Xmas in the The Welcome Forum area at ElectriciansForums.net
