T
the phoenix
Hi, my 1st post which I hope makes sense.
Will this wiring diagram work, any info greatly appreciated.
If I put a + feed from sidelight to pin 85. Will it then turn DRL off, when sidelight is turned on?
Any help is appreciated.
Without the internal connections of the Bosch relay this has no meaning!
TBH this diagram doesn't make sense you have a battery supply direct but only 1 wire to the fuse ...so assume that a permanent supply to the relay and a fused supply via the switch to the coil, so 86 and 85 are your coil and 30 + 85 are you switch N/O contacts.
Ignore my ignorance, what is DRL then I can guess you answer.
I know what you are saying Darkwood, but in his defence all automotive relays follow a standard number scheme and an auto electrician will know exactly what each of those terminals does from the numbers.
Basic auto relays come in two types, 4 pin and 5 pin
85 + 86 are coil
30 is common
87 is N/O
87A is N/C (missing from 4 pin relays)
Either way whatever you do to that relay in the diagram it won't affect the DRL as there is no connection to any DRL! It is shown controlling driving lamps or fog lights.
Connecting the +ve from the sidelights to pin 85 of that relay will bring the driving or fog lamps on whenever the sidelights are on, this will contravene vehicle lighting regulations and make the care illegal for use on the public roads.
Also the circuit shown is no good for driving lamps as they need to be linked to the main beams such that they can only come on when main beam is on, they must not be able to be switched on whilst only dipped beam or sidelights are on.
You would normally take the feed for the control cct from the main beam switched feed (blue with white stripe in old british colours) not direct from the battery or ignition feeds
(DRL is daytime running lights)
Cheers Dave ... I worked it out and edited before you posted but im a tad drunk so slow off the mark ...what is DRL?
Sorry, edited my post a bit also.
DRL is daytime running lamps, another load of nonsense forced onto us by our european masters.
They are the white lights on the front of new cars which are on when no other lights are on and the engine is running, a lot tend to be some kind of LED lamp. I'm not certain if they go off when sidelights are switched on or not though, my involvement in vehicle wiring is limited to my trusty landrover which pre-dates all that nonsense.
If the item labelled fog / driving lights is your DRL then it would need to be connected to 87a not 87 and then when the sidelights switch (assuming that is switch SPST) is turned on then the relay would operate and hold the fog /driving lights off.
it's a stupid idea. as an ex-biker, once when you saw headlights on in daylight, you knew it was a motorbike and were more aware. now every numpty drives around in sunshine with headlighs on.
I never asked the question is it a stupid idea or not, I simply wanted to know if the diagram would work. Obviously from some of the more decent replies it might not work.
Ex-bike driver that means you saw the light and stopped and now drive cars then!! Thanks for insinuating that "I'm a numpty" too.
We see adverts saying watch out for motorbikes when in fact they should look out for themselves the way some of them drive.
I searched this forum for a while before I asked the question and noticed a few members received a good few sarcastic comments when asking a simple question as they thought and heard it was a friendly forum.
After this thread I can see where the folks are coming from.
Friendly it definitely is NOT!
it certainly is a friendly forum. if you look at a few threads, you'll find a mixture of good advice, some humour and also sarcasm. a bit like real life, really. and i did not mean to insinuate that you personally were a numpty.
I think your drawing has caused confusion as it's a standard fog/driving light one probably found on the web?, just need to replace fog/driving with DRL?.
To make the DRL's switch off when sidelights switched on you need another relay (same as shown)
Cut red wire between fusebox and on/off switch and connect as follows
30 - feed from fusebox (cut red)
87A - feed to switch (cut red)
85 - feed from sidelight circuit
86 - ground
87 - feed to switch (cut red)
86 - ground
Thanks for your reply, greatly appreciated and yes the diagram was taken from the web, sorry for ant confusion.
I prefer not having to remember to switch them off at night when you have you headlights on, so I would wire them like this:
DRL's on a switch/relay
Auto Electrician Forum
Thread Tags
the phoenix,
LairdScooby,
