Discuss Dust covered breakers , an issue ? in the Electrical Tools and Products area at ElectriciansForums.net
Mikegh
I'm doing a major reorganization ATM
So I've a box of about 30 unused breakers which I threw under the bed and they've gathered dust.
Is the dust a concern or can I just blow it off with the vac ? Thanks
Dust could migrate into the internal mechanism, so yes could become an issue
Yes that's What I was wondering. They're not that bad but I can see dust has gotten onto the open DP neozed so dunno about that.Silly to leave the box unopened under a bed it's a magnet for dust
The original post mentioned 'unused breakers' which kind of sounded like they were new and maybe worth salvaging. But the photo seems to show a box of what looks like old & very well used breakers that I'd have to be desperate to want to fit in a distribution board!
They're not very well used, they are unused
Possibly a few used but I doubt even that
I've no intention currently to stick then into a DB but wasn't intending to bin them either
I have a site where we standardised on MEM Memshield2 boards some years ago (previously we had every make of DB under the sun!). I have drawers full of used MCBs ready to swap out in case of failure or change of circuit. Some look slightly dirty on a par with the OPs picture but can't say I'm worried as a quick clean will get them looking pristine again and the inner workings are quite well protected against dust ingress. Now if they were sitting on a shelf in a workshop with dust and crap all over them I might be concerned!
I've never known normal dust to cause problems with MCB's but I've seen a few fail when some idiot drills or chisels plasterwork above a CU or DB and the cement and brick debris got inside them.
Reply to Dust covered breakers , an issue ? in the Electrical Tools and Products area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hi all. DIY here. Electric Dryer (Kenmore Dryer - 796.61552.610) had been tripping the breaker sporadically over the past few months. Recently the...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
