P
Pud
ok a couple of questions
ill keep it simple
its been ages since I had anything to do with E7,
is an E7 board supplying storage heaters still ok on a non rcd board ie classed as fixed equip ?
who is responsible for the tails? from head to meter and meter to board
thanks
Hi - if you are putting in a new board then the installation method of the circuits must be considered. So cables in walls less than 50mm would lead to RCD being needed, for example.
Edit - what ^^^ said :)
Pud,
Wilko,
