Discuss Earth wire loose under sink - advice in the DIY Electrical Advice area at ElectriciansForums.net
smcshaw
Hopefully a very quick question. Whilst looking under my sink this morning I noticed the Earth wire between the hot and cold pipes is no longer connected. I can't recall if it ever has been but I'm assuming this has come loose and I should reconnect it? If I do connect it should I take any precautions, i.e. flip the fuse off? Thanks in advance.
that cable (or a similar one, can't see from pic.) should connect to the cold water pipe. as close to the stop tap as practicable. generally no requirement to connect to hot.
Looking at it, it appears to have just come out of the clamp (with the red tag visible in the photo). You should be able to reconnect it quite easily if you've got a flat bladed screw driver.
if you bend that red label up, you'll see where it was connected. you can just see the edge of the cable clamp below the middle of the label. cable does not connect to the visible screw, that's the clamp screw.
Reply to Earth wire loose under sink - advice in the DIY Electrical Advice area at ElectriciansForums.net
I recently bought a bathroom mirror with LED & Bluetooth speakers (from Amazon). There is a double isolated symbol on the back of the mirror yet...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
