The sheds still metal, test for an extraneous part if not carry on😎
Absolutely right cliffed. I will definitely do those tests to determine if it's extraneous or not. As I've just replied to Westward I'm confident with installation but real world experience (as I'm a trainee spark) is limited so just want to lock all details in. I appreciate your help on this and not being a dick about it that something I'm saying may seem obvious to most 😅
A fault like that would need a lot of things to go wrong at the same time, and someone would have to be touching the shed when it happens. Earthing the SWA at both ends gives me full continuity and a reliable fault path back to the house RCD, which massively reduces the chance of the shed ever floating live.
It requires only for the case to be in contact with the metal structure (which in my experience is extremely common) and one fault in the appliance or its lead to allow the mains filter to liven the metal case - but then how could I possibly know that as all I have is a 16th ticket.
I have offered my opinion based on >50 years dabbling with wires and pliers and many metal structures along the route?
As you are a trainee, should you not be asking those training you rather than a random selection of different opinions from strangers?
I for one have always been delighted when my trainees ask questions as long as they don't repeatedly ask the same questions week after week.
I am retraining whilst working part time so not actually on site and don't have a "mentor" as such so it's a bit of a pain for me 😅
Ihave my final set of GOLA's this weekend, 2365 (602, 210, 203) 2382 regs and 2393. I've passed all practicals so looking forward to getting these done. I will then be looking in the new year for a full time position as a 'mate' and carry on my education.
Andof course sunray I didn't mean any disrespect with my message and 100% appreciate your input. Poor wording on my part perhaps.
I feel your pain. I grew up with electrical work with my father, worked in telecoms for 22 years then redundancy sent me towards my hobby of Public Adress/entertainment which of course included video/lighting etc Then redundancy due to 9/11 I found myself in control systems (commercial air handling/heating/cooling/process control etc) Other than courses/test on things like safety/grinding wheels/scaff tower/first aid etc I've had no retraining for the different genres since my telecom days except I took 16th a good many years back to lay some of the 'your not qualified' statements. However the vast majority of my work has been under qualified persons/companies so that has not been too much of a hindrance while my day rate has frequently been significantly higher than that of qualified sparks I work under due to my experience/ability/knowledge and on numerous occasions corrected their mistakes due to lack of experience/ability/knowledge.
Thank you HHD, my plan for both tests works be to use an MFT and wander lead between shed and my MET at the board. Flick between continuity setting (looking for a high reading indicating no connection to earth) and then the voltage setting and hopefully get a 0 Volt reading indicating 0 touch voltage potential.
If both tests read in this way I do not require earthing of the shed.
Can somebody confirm my thoughts on this or am I way off? 😅🤦‍♂️
I would say you are way off.
A reading of zero Volts in this test will tell you nothing about what would happen under fault conditions.
On the standard continuity range of the tester you will almost certainly get a very high reading, switch over to the insulation resistance setting and you will get a more realistic result.
But as this is outdoors the results will be constantly changing throughout the year with the weather and ground conditions.
So I can do an IR test as well then to rule out everything and proceed as that's all areas covered? It's very difficult to test every potential scenario, I can only go with what's Infront of me. But it will either be wet or dry.. as it's on concrete and a membrane the ground conditions will have minimal effect. Would that be the right way of thinking?
Will the person touching the metal shed during fault conditions in the rain also be standing on the membrane?
If the structure is proven not to be an extraneous-conductive-part through testing it does not require a main protective bond regardless of the what ifs and what nots.
Yes knowing earthing something that does not necessarily need it can actually be hazardous.
Indeed, which is one of my pet hates, as is using a brass gland on the end of a SWA TN... feed into a TT installation.
Having worked in/on multiple metal clad buildings which have become live due to a fault I know which route I'd go down.
However as I've already said; I don't have the tickets so I'll offer my opinion based on experience but happily bow to qualifications.
