Discuss Economy 7 - 7 Day timer? in the Industrial Electricians' Talk area at ElectriciansForums.net
49er_Jerry
Hi Everyone, I am new on here,
I have a customer who has a property heated by Economy 7. They work away 5 days a week and are only there at weekends. They do not want to heat the property fully when they are not living there.
Is there a 7 day programmable timer that can be installed to control the E7 circuit in the property, or is this a no go problem?
Isolating the CU is not a problem. The problem I am having is finding an E7 programmable timer that will operate both the heating and water using settings for individual days.
They want to have the same flexibility with the settings as a standard central heating control. During the week when the property is empty, the E7 will be on for a shorter time, but programmed to heat the property for their return at the weekend.
If they have a seperate cu for the E7 why not run from the relevant mcbs through a contactor to the heating and water. Control the contactor with a 24/7 timeclock running from the standard supply cu. Just a thought.
good idea that tony, gotta be the best way of doing it, or why dont these people just press "boost" on the water when there home and same on the heaters?
other thing as well i could be and probably are wrong but would it be more cost efficient to keep a water cylinder at temperature than to heat it up from cold??
Reply to Economy 7 - 7 Day timer? in the Industrial Electricians' Talk area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi, My hot water hasn’t been working properly since beginning of Jan, only working when I press the boost mode for an hour. I had a new timer...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
