Discuss ECR - Wood Block light switchs in the UK Electrical Forum area at ElectriciansForums.net
W
workbelt12
Carrying out a ECR. House rewired about 5 yeays ago, wood block light switchs fitted thoughout. No flush back boxes & cables stripped off sheath behind . Be interested off your thoughts :saddam:
First thoughts are C3, but there is a lot of reproduction stuff about that isn't what it appears, and it could be OK, you need to see if you can find a BS or BSEN number anywhere on it, if you can then look up the spec before you condemn anything. You will look a proper berk if you get this wrong.
If no BS, then you will have to give the bad news.
Cheers…………..Howard
Reply to ECR - Wood Block light switchs in the UK Electrical Forum area at ElectriciansForums.net
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello, My house has 25mm back boxes throughout, but I’ve noticed the previous owner has installed sockets and switches that seem to...
