Discuss EIC additional circuit main switch/switch-fuse/circuit breaker/RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When doing an EIC for an additional circuit (which only covers that circuit), does the 'main switch/switch-fuse/circuit-breaker/RCD' section refer to:
a) the MCB you're adding for the new circuit
b) the existing main switch (whatever it is) for that board
c) [if the DB the circuit is added to is a sub main fed from another DB] the breaker supplying the sub main
And, in the case of (c) would the 'supply protective device' under 'supply characteristics and earthing arrangements' still be the DNO's main fuse, or would it become the breaker supplying the sub main?
TL;DR
What does 'main switch/switch-fuse/circuit-breaker/RCD' on an EIC refer to?
The Main Switch is the main switch for the installation. Supply Protective Device is the DNO device so probably NV.
Reply to EIC additional circuit main switch/switch-fuse/circuit breaker/RCD in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Hi, I'm back in the electrical game after 9 years break so feeling a little rusty! I'm adding an additional socket to a circuit but the main RCD...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
