Hi,
I've got to a point where I need to complete the EIC for the caravan I've been working on. This isn't a static caravan, so will be going from place to place where they may or may not been mains hook up.
Dead testing has been easy, that's been no different from normal and the RCD tests have been easy, but now I'm onto the Ze and Pfc tests which, as you can imagine, are not quite as straight forward, in fact I'm not even sure it's possible to do given it has three sources of power - battery, solar and mains and a combination of all 3. Even just on battery power the values will be different due to the different ground conditions at the location where the caravan might be, and mains the same issue.
The EIC is required for insurance and inspection purposes, my CPS also requires it. I just wondered has anyone had to produce an EIC or something similar after installing 230V electrics into a mobile caravan ?
