Discuss EICR Codes in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Done a report yesterday. customer is about to complete sale of house, so obviously wants a satisfactory report. i gave the following codes for some non-compliances:
no cpc on lights with metal switches ,,, C3
no RCD protection on bathroom circuits and no supp. bonding.... C3
large holes in top of CE... taped them over... no code
5 double sockets unfused spur from ring final.... C3
cables buried in walls outside zones, run diagonally .... C3.
so a satisfactory, everyone's happy, got a £20 tip.
do you all agree with the codes . hate to have a sale fall through if there were C!'s and C2's.
or do you all think i've been too lenient.
can you edit you post then, lets do some wind up/
Had you did not code it?
You could have got a rewire out of that as it is not up to regs and should be band from use, you have to go back now and disconnect it put a big sticker on it and charge then another £20 plus the price of the sticker
Sticker wording is up to you
Tel would never do a drive-by he's A proper sparks
And his van has to stop every 20 yards so the engine can get its breath back
van's fine it's got a turbo thingy to breathe through. like jacques coutsteau., or is it inspector clueseau?
the charger is independent of the turbo. it's a different lump bolted on. think it's called an altermotor.
Reply to EICR Codes in the UK Electrical Forum area at ElectriciansForums.net
Private tenant since 2011. First ever eicr February 23 informed via text it failed by text from electric secretary arranging appointment for...
Morning, Company had an external contractor coming in to complete an EICR recently. They have gave us the report with a C2 for holes in trunking...
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
13K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Can I get everyone's opinion on the following please for EICR coding? TN-C-S INSTALLATION Ze = 0.26 Pfc 0.9kA SUPPLY FUSE IS 60AMP 1361...
5K
Deleted member 4632
