I agree that it's best to do an EICR before a CU replacement, but is there an actual regs that dictates that an EICR 'must' be conducted prior to a CU change?
No it's a recommendation via a best practice guide
Can be tricky.
Could be just a single board that needs replacing, could be a couple of boards, a few switch fuses and half a dozen Henly blocks.
How much is charged for a typical EICR?
I was just wondering; most of my CU changes were for small or standard sized properties. I couldn't possibly factor in the cost of an EICR, and even think I would get the CU replacement.
If it was for a very large property, or the existing install looked a bit dodgy, then I would carry out an EICR for a fee, followed by a quote for the CU plus any extras that where located by the EICR.
This seems to be a very common question asked, shame there's not one of those sticky threads on CU changes; EICR's beforehand, intumescent sealing of, protective bonding size, tail size, CU location/height etc etc.
“Be lucky to get £15 a cctaround here(Yorkshire) “
One of the reasons I now live in the Isle of Man instead of Donny
