Discuss elecsa safe isolation in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Steinel type tester with self-test should suffice.
A guy i used to work with went the whole 9 yards and got one of those actual test lamps off of college, with the proving unit and everything, but you'd be looking at the best part of 100 quid for something you're only going to use once.
Mmmh, i actually use mine regularly !
WHAT!! Are you saying that you dont actaully test the live source, isolate, test on proving unit and then padlock everytime!! Good god. I must stop doing this then too. I mights save 3 hours every day.
Likewise. I asked the assessor shall I demonstrate safe isolation? I had the lockoff devices, lock and warning sign etc in my kit. He said no don't worry, we're the only ones here! Also used the incoming tails to prove my voltage tester.
Reply to elecsa safe isolation in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi all. Just a quick one if I may. I am currently about to fit 3 gang smart touch switch at my front door but owing to powering two sets of...
Hi I am looking for advice please. Last week I done my am2. And the only thing I failed on was safe isolation of the 3 phase circuit. The...
5K
