Electrial Rf interference, theory and practice of using Ferrite Ring Cores 'choke' | on ElectriciansForums
Discuss Electrial Rf interference, theory and practice of using Ferrite Ring Cores 'choke' in the Electrical Engineering Chat area at ElectriciansForums.net
ChrizK
UK
I appreciate that @mark641 asked how ferrite cores work here, answered by @Lucien Nunes , but TBH, it is at a deeper level than I need.
My question is more so in regard to the practical use of them.
I (unfortunately) bought a Road Angel Halo Pro dashcam ...I bet you can already guess the problem ...my DAB Radio.
Speaking to Road Angel, they say that they are aware of the problem for 'a few' customers. My immediate response was 'but if it is only a few, does that mean that some units are faulty producing interference that others do not?'. They refused to accept this but could not give me a reasonable answer to the question. However, they suggested a Ferrite Core, to which I answered, I already have added one and it makes no difference. They then suggested adding three ... my response being ... "these things are big and I have just spent the weekend hiding the cables in the trim".
Anyway, I ordered 20(!) from Amazon and proceeded to clip three onto the cable, despite it being completely impractical. As I had guessed, it made no difference. I clipped a further two onto the rear camera, still no difference.
This makes me wonder 'how' best to 'apply' these things. I have seen the cable looped around the core, and alternatively fed straight through. Is there a difference/recommended way? Also, where does the interference 'come' from? I heard one comment that the core should be located as close to the 'device' as possible. Is that correct? This interests me ...is it correct that the device (in my case, the dashcam) creates the interference, but it is the cable that becomes an antenna, which 'emits' the radio frequency?
Considering that I have wired in a 'female cigarette' connection to the car fuse board (using a fuse piggyback), is this also a device?
ie is it valid to add (yet more) cores at this end as well? This perhaps goes back to the question 'is there any value adding more and more of these?'.
Sorry for all the questions, but hopefully someone can be kind enough to reply in laymans terms (and apologies if I have ended up in the wrong forum, but it made the most sense to me!)
The dashcam generates RF internally, some of which escapes along the power cable and radiates from it, or continues along the vehicle wiring and gets into the radio. Connections along the chain such as the lighter socket do not contribute, although if the 'plug' actually contains a voltage regulator to send say 5V to the camera itself, then the regulator might just possibly be the culprit. (What is the plug like and how is its output connected to the camera... USB?). One wants to trap the RF as close to the source as possible. If the source is the camera, as you have fitted ferrites there without any effect, either the radiation is not from the cable (it might be radiating straight off the circuit boards and through the body of the unit) or it is at frequencies at which the ferrites are not effective. Adding more cable turns can increase the attenuation, but if there is none with a single pass through, adding more probably won't make any difference. You might try moving the unit relative to the car body and radio, while listening for the effect. If that makes much more of a difference than moving the cable, then the cable might be a red herring. The same applies to the rear camera and the voltage regulator in the plug, if there is one. BTW did you simultaneously fit a ferrite core to the rear camera connection leaving the front unit, as well as near the rear camera itself?
The reason only some customers are experiencing this probably lies in the different vulnerabilities of their radios. The dashcam might be naughty in radiating too much interference, but equally some radios might be naughty in not being adequately screened against it. Mutual interference has been an ongoing issue with electronics for over a century and a significant fraction of product R&D and cost is associated with controlling it both inbound and outbound. Some pairings of devices are going to be more problematic than others. It might be showing up some deficiency in your aerial or aerial wiring that has otherwise gone unnoticed, i.e. the aerial signal is weak but adequate (with digital, you might not be aware of a problem via the audio) in which case the interference is relatively much stronger.
Thank you @Lucien Nunes , I hadn't thought about 'the other end' properly. You are absolutely correct to guess it is a USB connection ... I am attempting to use the cable provided with the dashcam, rather than the additional purchase of the Road Angel 'hard-wire kit'. (considering I already have a cable, I not only consider the price of the HWK12 to be expensive, but also note comments saying that it is not correct for the new model ...no idea if true, but thought I would try an alternative).
I will try adding a core at that end too (along with the existing cores at the front and rear cameras).
Your advice and insight is greatly appreciated, although I am not sure if I will try all the investigation suggested ... I may find it is the camera position in relation to the radio, or the radio itself, but that ultimately means I can't use them together, so I end up down a blind alley :(
...just re-read your question ... could it be beneficial to remove the core at the front camera, leaving the core at the rear (which is as close to the rear camera as possible)? ...sorry, re-read again (and remember how I first understood) ... "leaving the front unit". TBH I can't remember where the cables split. I will have to remove it all as it is all 'nicely' hidden in the trim. Another job for the weekend.
You were absolutely right to direct me to do more investigation. I pulled all the cabling out and added a ferrite close to the USB socket (inserted into the cigarette lighter as described earlier). The radio came on and I thought BRILLIANT! I then put everything back in place. Later went for a drive and the radio cut out continuously.
The bit of information I didn't provide ... the back camera was dangling from the trim as I didn't want to commit sticking t down with 3M double sided until it was all working. When I thought it was working, I stuck it to the back window. I asked on Ford Owners Club how to hide the cables at the front of the car, and an excellent contributor responded with a detailed answer (although I received this after I neatly installed everything). He told me to be careful of the car aerial and not to attach to the window(!). After investigation, I found that what I thought were heating elements in the back widow, also included the aerials (FM and DAB). So, I had stuck the camera pretty much right on top!!! Anyway, although I had two ferrites attached, after prying off the camera, I found no matter where I placed the camera on the top ledge/surround, the radio cut out ... as the aerial receivers are in very close proximity.
My problems seem to be resolved if I place the camera at the bottom of the window ...but the ledge has an acute angle, so the camera points straight at the sky. Not really sure what to do with that. Guess I need to make some sort of platform :(
At least I think I know where the issues are, and very much appreciate all the knowledge you have passed on, as it has meant I have some confidence that I have done all I can in the front of the car.
NB I should add, I placed a ferrite where the cable splits to feeding the rear camera. This is actually fairly close to the front camera, but I don't think it made any difference.
Have you checked the USB supply? I'm a radio ham and many years ago I found a mysterious signal appearing on 2m and 70cms in my car. Eventually traced it to the plug-in usb in the cigarette lighter in the car feeding my mp3 player, changed it and no more problems. This also cropped up recently with some other usb-using stuff with the same result, I think the interference depends to a great extent on whether the converter is a switched-mode type or a simple voltage divider.
Thanks for your reply.
I need to build a platform and so the rear camera is still dangling.
The radio mostly works, but it cuts out in areas (irratating) which I am fairly sure is interference from the camera setup.
I may have to venture back to the USB. I guess I should have used the actual cigarette lighter socket before going straight in and wiring in an additional one. Would have been a lot easier to play around to determine the behaviour before concealing everything!
One thought: if you have one of those power banks with a USB output try connecting that to the camera so it's not physically connected to the car electrics. That would establish if the interference is going through the car wiring from the plug or being radiated and picked up by the wiring.
Reply to Electrial Rf interference, theory and practice of using Ferrite Ring Cores 'choke' in the Electrical Engineering Chat area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
Tags Cloud - Most Used Words - Use them to search for topics
110v 12v 17th 17th edition 18th 18th edition 2 way 2330 2365 2391 240v 3 phase 6mm access account across adding additional advice advise after again alarm alarms always am2 amendment amp another answer anybody anyone anything appliance appliances application apply apprentice apprenticeship approved area arial armoured around assesment assessment attach aus ausie elec available basic bathroom batteries battery because become becoming becsa before being bell best better between black block blowing board boards boiler bonding book books bosch box boxes brand breaker breakers british bs7671 bsi build builder building bulb bulbs business button c&g cable cable size cables calculation calibration camera can't canada car caravan card career cctv ceiling central central heating cert certificate certificates certification certs certsure change changes changing charge charger charging cheap check cheers christmas circuit circuits clamp class code codes college combi coming commercial companies company competent complete condition conductor conductors conduit confused connect connected connecting connection connections connector connectors consumer consumer unit contact contactor content continuity contract contractor control controller conversion cooker copper core correct cost council couple course courses cover cpc cps crabtree cupboard current customer customers dead deal degrees demand design details detector device dewalt diagram difference different dimmer dimmer switch dimmers distribution diversity diy dno doing domestic domestic installer don't door double downlight downlighters downlights drill driver earth earth rod earthing east economy economy 7 ecs edition eic eicr elecsa electric electrical electrical installation electrical nvq electrical tools electrical wiring electrical work electrician electricians electricians london electricians mate electricians vans electricity electrics electriians mnchester element email emergency emergency lighting employed energy engineer engineering enough entry equipment essex every everyone exam existing experience extending extension external extra extractor extractor fan fan fans fault fault finding faulty fcu final finding fire fire alarm first fit fitted fitting fittings fixed flat flats flex flickering floor fluke fluorescent for sale forms forums found free fuse fused fused spur fuses garage garden gas generator get getting going great green grid ground gu10 guidance guide guilds hager halogen happy having heat heater heaters heating hello help help please help! hi everyone hnc hob home honeywell hot tub hours house how to ideas immersion impedance improver in london incoming induction industrial industry information infraction inside inspection inspection and testing install installation installations installed installer installers installing insulated insulation insulation resistance insurance interesting intro introduction inverter inverters isolation isolator issue issues jib jib card job jobs joining junction keeps kewtech kit kitchen knowledge lamp lamps large lead leads leakage led length lenny level level 2 level 3 light light switch lighting lighting circuit lights little live load local location loft london long looking looking for work loop low voltage ltd machine main main switch mains maintenance makita manchester manual mate max maximum mcb mcbs mcs media megger member members message metal meter meter tails meters method metrel mft might minor missing mobile module money motor mounted mounting moving multi multifunction multiple murdoch myself napit need help needed needs neutral never new new build new member newbie niceic night no earth north not uk not working notifiable number nvq off offer office old online opinions options other out outbuilding outdoor outlet outlets output outside oven overload panel panels parallel part part p passed pat pat testing people periodic person pfc phase phone pipe pir place plan plastic plate please plug plumbing advice pme point points pole position possible post posts power practical practice price prices pricing private problem problems project property protected protection protective pump pvc qualification qualifications qualified quality query question questions quick quote radial range rated rates rating rcbo rcbo's rcbos rcd rcd tripping rcd's rcds reading readings really recommend recommendations red regarding registered regs regulations relay remote repair replace replacement replacing required requirements resistance results rewire right ring ring final ring main roman roof room rose running safe safety salary sale saying scheme scotland screwfix sds second section security self self employed sensor series service services shed shock short shower simple single single phase site plan size sizing skills sky small smart smoke smoke alarms socket sockets software solar solar panel solar pv someone something sorry source south spark sparks sparky split spur spurs standard start starter starting steel still storage storage heater strange strip students stuff sub main suggestions supplier suppliers supplies supply supply to surge swa switch switched switches switching system systems t&e table tails taking terminal termostat test tested tester testers testing tests thank the forum their thermal thermostat these thing things thinking those though thought thoughts thread three three phase through time timer times tips today too tool tools trade trainee training transformer transformers trip tripped tripping trips trunking trying tt system type under underfloor underfloor heating unit units update upgrade urgent used using value values valve van vehicle video volt drop voltage voltage drop volts wall wanted warning water weeks welcome west what's whats where white wind wire wired wireless wires wiring wiring help within without work working works worth wrong wylex years zone zones
