G
GT1
Need to do a little jiggery pokery on a job where a square D CU is in use and I need to free up an mcb.
One solution is to fuse down the cooker (just oven/grill, no rings) which is currently on a 32 amp.
Now I know I can pull out the the cooker and check the plate, but I'm not there at the mo..... So I was wondering does anyone know what KW these appliances are typically rated at. ??
cheers...
cheers...
