Discuss Electric fire in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, just been asked the following:
''I have an electric fire that I have to turn on at the wall and then again on the fire. Recently have noticed that if I turn it on at the fire and not the wall it still works! Any advice?''
I'm thinking it must be a faulty socket switch, any sugestions welcome..
thanks in advance
Advice....
chuck it out, it's costing you a fortune to run....oh and get a sparky to change your socket..it's defective and potentially lethal....I wouldnt even contemplate plugging an electric fire in it. (Seriously)
Randyrat
Reply to Electric fire in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Dear All, I was called to a villa following a fire incident had happened. the Indoor AC, wall mounted split unit was partially melted and had...
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
