Discuss Electric knife: strange wiring: request advice in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
The knife is Russell-Hobbs, ECO1255, model 13892.
I work for a charity which receives (among other
things) electrical goods
which must be tested before we can give them to
recipients. The PAT meter gave weird results: normally
when the device being tested is switched off the meter
says "lo load", but on this knife it did not
do so. I tested further:
when the knife is off, the resistance between live &
neutral is ~~ 1/2 Megohm. So if you leave it plugged
in & switched off, it will
draw a continual leak current 1/2 ma. (that is an
estimate: I dont have a
meter to measure this). So I opened it up &
the supply wires go
into a PCB which I assume is for radio interference
suppression. And this PCB is upstream of the switch.
Please: is the knife supposed to be made this way
or is it defective?
Am I right in my belief that this violates
the Regulations?
thank you RM Damerell
Did you also check inside the plug?
Sometimes the flex can be damaged under the cord grip and needs to be cut and made off into the plug again
many electronic , rather than simply electrical, devices have a small continuous draw whilst on standby. you should be careful doing high voltage (insulation) tests on such an appliance. it can damage the components and turn a perfectly safe and functional appliance in to a piece of weee.
Thank you who replied. Plug is moulded so I cannot check it,
but while the knife was open I did check correct polarity.
R-Hobbs sent an email: it is faulty.
I will probably rewire to put the PCB downstream of the switch.
just plug it in. chickens, ducks and pigs don't care which pole cuts their heads off.
I'm a big fan of recycling stuff and avoiding chucking stuff away, but I would think carefully before modifying a product, especially if it is to be sold/given to someone else.
If you modify it from manufacturer's specification you are voiding the CE certification and also becoming the "manufacturer" of that appliance.
Reply to Electric knife: strange wiring: request advice in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
