6mm cable , if installed in a void, clipped, and/or buried in plaster ( as opposed to being run in insulation) is good for 47A, and can be protected by up to a 40A MCB. bear in mind that your range cooker will never pull more than 30A due to diversity. this has been a rule of thumb for 60 years. and, in answer to your other question, i am a qualified electrical engineer with 40 + years experience.
hi there , so 6mm might be ok, but 10mm would be even better?? .
if 6mm is ok then 10mm will also be ok, it won't be better, it'll just be a marginally more expensive version of ok.
If 6mm is ok then any cable of that size or greater will do the job, although if you go too big then you'll have trouble terminating it.
Hi Anna, to work out if 10mm might be required it would be good to know the detail of the cable run - its length and its installation method. In the right conditions the 6mm will be ok, but that's what your Electrician can best assess on site. I can't imagine needing 16mm :)
although if you go too big then you'll have trouble terminating it. - sorry to ask, what do you mean by that?
ok, so it is 10 m lengh from the consumer unit plus an extra 1.5 m from the oven to the socket (in order to be able to move the cooker). the cable will be running under the floor and partially in the wall. So up from the socket (in a wall) then uder the floor boards and then to the consumer unit. thanks
6mm is fine.
Tho it makes no difference to anyone on here as it's your electricians decision as he's installing the circuit and certifying it.
thank you so so much. ok, just a crazy question, please, if I would turn on all at once: 2 ovens, 5 ceramic rings, grill and plate warmer (eg. during Xmas), wouldn't it make installation crush?? i had already some problems with an elecric shower and it was just 10 kw:-(
You need to appreciate that a electric shower has a built in thermostat allowing no diversity to be applied to the circuit and is nothing really like an electric induction oven which incorporates heating elements which when reach temperature switch themselves off
No your electrics won't crush?
Whatever that means :)
thank you
just one more thing, please, but this time is not the cooker :-)
it is about the lights. my kitchen diner has some downlights in the kitchen part and just one ceiling rose in the diner part, I am adding as well 2 x under cabinet lights. so those 3 types of lights ideally would be linked with one tripple switch. but, I would like to have them dimmable, is this possible?
What had caused you to ask all these questions? I know you have conflict of answers but you aren't an electrician so as long as it is installed, signed off and gives no problems what does it matter?
