just one more thing, please, but this time is not the cooker :)
it is about the lights. my kitchen diner has some downlights in the kitchen part and just one ceiling rose in the diner part, I am adding as well 2 x under cabinet lights. so those 3 types of lights ideally would be linked with one tripple switch. but, I would like to have them dimmable, is this possible?
You can dim them as long as you have dimmable lights
The answer to the question that started this thread is written in the on site guide which a decent electrician should be aware of. I get this question regularly "oh the company came to fit the cooker and they said we need a bigger cable"...give me strength
If you are refurbishing your kitchen, best you find a 4th spark, via local recommendation and work with them.
although if you go too big then you'll have trouble terminating it. - sorry to ask, what do you mean by that?
The bigger the cable, the harder it is to work with, especially in the rather cramped conditions of a standard backbox for a cooker switch.
Plus I don't think 16mm would fit in the terminals of some brands of cooker switch.
thank you so so much. ok, just a crazy question, please, if I would turn on all at once: 2 ovens, 5 ceramic rings, grill and plate warmer (eg. during Xmas), wouldn't it make installation crush?? i had already some problems with an elecric shower and it was just 10 kw:-(
That's a pretty odd kind of dinner you are cooking where you turn all elements on at the same instant.
The last time I cooked a Christmas dinner the oven was a long time before the hob.
But anyway, the elements will very quickly settle down as the thermostats start to kick in, this is kind of the point of cooker diversity calculations.
What problems did you have with the 10kW shower? That is different to a cooker as it presents a single 10kW load whereas a cooker is made up of separate loads.
