Discuss Electrical Clamp for small home projects in the Electrical Tools and Products area at ElectriciansForums.net
GVCCRLM
This may be a stupid question, but I am trying to connect a resistor for battery home testing. The wire on the end of the risistors are short so they will not fit into the end of the clamp with a screw. I am looking for a clamp that you can tighten the rubber plastic cover so I can connect the resistor between two clamps for battery testing by clamping the positive, negative, battery leads. That way I can test batteries with a load. I want to place the short lead wire of the resistor into the handle of the clamp and tighten it.
Reply to Electrical Clamp for small home projects in the Electrical Tools and Products area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
I have an 5kW inverter and 48V Lithium battery with inbuilt BMS. As you would be aware, when inverter gets battery power, immediately the...
I am looking for a clip where there is an Allen screw in the handle to connect small wire? I want to have two clips where I connect resistors to...
Can someone tell me what the resistance should be for a Solar iboost Clamp? My clamp is regestering zero ohms and I want to confirm this is the...
4Dave C
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
