Discuss Electrical system using mains water pipe as earth? in the UK Electrical Forum area at ElectriciansForums.net
I'm looking to get a water meter installed on my property, as I don't use much water.
My water provider's website says this:
"When installing meters in properties built before 1996, it may be necessary to replace old metal pipes. Some older electricity systems still rely on the supply pipe providing an 'earth' - this is now prohibited. If you believe your property may have this system, you should contact a qualified electrician to ensure you have an adequate earth."
Is it a difficult or easy task to identify whether this may be the case? My house was built in 1938 and still has a very old electricity meter (the kind with clockface dials, not even a 'digital' read-out). Is this something a non-electrician could identify, or would I need to get someone out?
thanks!
Yep,pictures of the installation,would assist,but do not always match results of testing.
I tested a rod on one occasion,which gave poor results,and had only been in a couple of years.
The same property had an old,redundant steel pipe entering the property,which had fed an oil boiler,once,from the garden. The Ra of which,beat the rod,by a factor of four.
I also remember several properties in north Manchester,all semis,on one road,which were TN-S,but had sweated solid core singles,to short,roman spear like rods,inserted a few feet away,in the sub-floor space.
Reply to Electrical system using mains water pipe as earth? in the UK Electrical Forum area at ElectriciansForums.net
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hi everyone! Im not an electrician but just a guy looking for a possible answer before I call my electricity supplier. Every month without fail...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Can anybody advise? I have a 3 rate old style electricy meter with 3 rates (day, night, and stored energy) Storage heaters are completely off at...
